Hey guys I recently ran the disk error checker on my pc. The next day when I wanted to login to windows it just loads and goes to a black screen. I can see my mouse pointer. I could not access ctr+alt+del either. My pc can login in safe mode. I tried uninstalling anything recently installed, ran an avast anti-virus scan as well as a superanitspyware scan but nothing stood out. I ran ccleaner and combofix also with no luck. I tried uninstalling my display drivers, which only seemed to let me access my task manager during my black screen. Any suggestions?
Thanks a lot for your time.
Which version of Windows is this?
Open up the task manager and select file-> new task->explorer. See if your desktop then appears, if it does, Please post back asap. I've come across this and its something you need to fix in the registry - if its the same sort of error that I ran into though :)
Why did I never see this post? -_-
Have you tried doing a system restore? You should be able to do this from safe mode. On the other hand this was posted a month ago so I'm guessing that you've found help elsewhere or formatted and reloaded. Doesn't sound like a virus or spyware. Sounds more like a registry issue to me.
Let us know if you have any updates on this or still need help in any way.
