Hey christo thanx so much :) yeah my HD is VERY OLD infact the oldest component in my case other than my keyboard (not in my case) xD..
i downloaded the full installer and was lil confused as there where about 100 zip files? with names like "Apr2005_d3dx9_25_x86" etc so im not really sure what to do with each 1
and additionally i downloaded the smaller installer when i run the exe (dxwebsetup) i accept the agreements etc
then it initializes then i get the error "setup could not download the file. please try again later or check network connections"
my internet is working fine...?
Thanks a lot!
Here is the file.
That's perculiar it didn't work?
Zip the file before attaching as TXT files may contain unwanted scripting or malicious code. ;)
