This could be more than just that. You have to take the MEDIUM in which you transfer video from device to monitor into consideration as well as the DISPLAY itself. No point in playing a HD movie (1080p) on a Monitor with 1280x1024 res or even 1600x1200. This will cause degradation in clarity. You have to compare apples with apples. If your PC's LCD supports 1920x1080 then use that as your HD display image and compare then. Baring in mind that this should be the "Recommended" res for you monitor and not forcing it to it.Enigma_2k4
I have noticed that playing blu-ray movies on my PC it's a bit grainier then the PS3. However, that could be because of the codec settings and the other enhancements that can be used (sharpening, etc). I've resported to going back to using the PS3 where-ever possible.
I've encoutered frame-rate issues on Win 7 when using the TV-out which I havent experienced in WinXP. There are also a number of latest driver updates on nVidia, ATi and Intel's site to sort out a lot of Win 7's display issues.
MayheM
If it is in fact the fail DRM (Protected Video Path) then apparently (according to wikipedia) it has already been bypassed...
Here's the article:
Sure, there's unintentional degradation due to a poor setup like you've outlined. But the type of degradation I'm talking about is not due to mismatched sources and output. Its intentionally built into WinVista/Win7 by Microshaft. Egregious behaviour on their part. But of course, we're all gonna smile and take it, just like we always have.MayheM
...You have to take the MEDIUM in which you transfer video from device to monitor into consideration as well as the DISPLAY itself...
Interesting. Frame rate issues are usually due to insufficient processing power (underpowered computer). However, sometimes its a hardware/driver issue. Be sure to post a thread if you'd like to hash the issue out.MayheM
If *only* nVidia released an updated WDM driver. That would be nice.MayheM
Will check it out when I get a chance ;-) Remember, there is a dedicated subforum on PCD for posting links to websites that you find interesting or useful.Enigma_2k4
I found an amazing site by the way : http://www.hack7mc.com/ - it's brilliant! So much very very useful stuff there!
]Also, you need to include the http-colon-forward-forward part when you create links using BBCode (the square bracket tags that PCD and other sites that share this website template use). Otherwise, the link becomes corrupted.
Morgue[FLB
