, any suggestions? I want to be able to use uTorrent at max speed running a BUNCH of torrents at the same time, without having my internet connection throttled and eventually killed!Nope, I haven't tried with FlashGet yet. Although it does support torrents, I find it to be an inadequate torrent client. As I say, this may only occur with uTorrent - a different torrent client may be fine. I'm hoping to solve the uTorrent issue, rather than apply a quickfix like trying a different client :)MaTiCa
Question, have you tried the same with FlashGot? Just wondering whether it's a compatibility issue of uTorrent with Win7 or is it the torrent files themselves?
That's odd indeed.MaTiCa
On a side note: I actually had similar problems with uTorrent and XP a while back... But then one day it just worked fine... o_0
Morgue[FLB
1) Which torrent client do you use?
2) What are it's connection settings (max connections per torrent, etc?)
3) This connection problem may not be noticeable on 100mb torrents. But it definitely occurred on my PC with a 180mb torrent.
