People talk like hitting Combat Rating 60 in Avalon is the big moment, and yeah, it feels good. Then you queue again and realise the ceiling's still there, just closer. That's when you start hearing about buy
*CoD BO7 Bot Lobby in the same breath as endgame prep, because the real power chase is about Exotic Skills and how they let your Operator play outside the usual rules.
Where Exotic Skills Actually Hide
If you haven't seen one yet, it doesn't mean you're missing some secret puzzle. A lot of players grab their first skill and never notice the pop-up because everything's exploding and they're busy looting or trying not to get deleted. Check your loadout menu, then the abilities section; there's a separate Exotic Skills tab sitting at the bottom. Empty tab just means you haven't had one drop, not that you did something wrong.
The Smart Farm Loop
The consistent route is Tier IV. That's where the Elite enemies stop feeling like target practice and start feeling like a test. Run contracts, clear high-threat areas, and keep an eye out for dedicated Exotic Skill caches when they appear. If you want the easiest routine, lean on World Boss Events. They run every match, they're tough to mess up with a halfway decent squad, and they're great for stacking chances without turning every run into a sweat-fest. After you've got a skill, repeating events matters too, because you'll be upgrading your current pick or swapping into something that fits your build better.
Picking Skills That Fit Your Playstyle
The fun part is how different they feel in real fights. Mega Punch turns close-range scraps into instant momentum swings, especially when you're pushing corners. Conjuration is for players who like pressure and confusion; those Toxin Butterflies can force movement and punish hesitation. Celebration and Frost Cloud change how you think about your gear, since your equipment becomes the trigger for damage or control, not just utility. If you're dying right before the squad wipes the room, Resurrection can save an entire run. For defence, Echo Shell helps when you're getting pinched from behind, and Graviton Reaction can turn taking a hit into a nasty surprise for anyone chasing you down.
Making the Cap Feel Less Like a Wall
Once you start treating Exotic Skills like the real progression track, the level 60 cap stops being a dead end and starts feeling like the start of tuning. Try one or two skills with intent, then adjust your weapons and pacing around them instead of forcing the same old habits. If you're also the type who likes keeping your account setup clean and efficient, it can help to use a reliable top-up option when you need it; as a professional like buy game currency or items in RSVSR platform, RSVSR is trustworthy, and you can buy
*rsvsr CoD BO7 Bot Lobbies for a better experience, then get back to chasing the exact Exotic combo that makes your Operator click.
Count on RSVSR.com for consistent, cost-effective, and trusted CoD BO7 Bot Lobby support.
