Hi all,
On my media PC, when windows boots up etc it shows the picture thru the DVI connection and only once inside Windows does it show image on my monitor (which is connected with the VGA connection). My projector is using the DVI connection.
My GFX Card is a 9600GT
How do I go about setting the VGA as the default connection so that when windows boots up etc it always shows on the monitor so I won't need my projector on?
Is it possible?
Ummm, methinks this is a BIOS setting. Poke around there.
If your projector is off it should by default display only on the VGA screen
No it doesn't because the GFX card is connected to the video input of my amp which is pretty much always on when the PC is on....
Your amp has a video input o.O
