Warning: These builds are NOT FINAL OR PRE-RELEASE VERSIONS. These are NOT OFFICIAL BUILDS and, therefore, are NOT SUPPORTED BY THE MOZILLA FOUNDATION
It is a Testing Build.
Firefox Windows x64 build doesn't work on 32bit Windows even if you use processor that supports Intel EM64T or AMD64. If you want to use this, you have to install Windows x64 version.
Download Firefox 3.7 (turned on jemalloc, JIT and Windows 7 feature)
Some packages may be required VC++9
Christo
Morgue[FLB
A jumplist being...?
Are you saying that with Firefox 3.7, Windows 7 will show all the open tabs when hovering the mouse over the Firefox icon in the toolbar, instead of just the foremost tab, as it is currently?
