Storing your music on the computer is great, but it can be a hassle if you're not around your computer. If you're going for a drive and want something for your car's CD player, you can use Windows Media Player to burn songs to a CD that's playable in standard CD players. The process is quite simple, and it's built around the playlists you've already created in Windows Media Player.
Follow these steps to burn a CD:
Insert a blank CD into the CD burning device.
Select Copy to CD or Device on the left side of your Windows Media Player.
Use the left drop-down menu to select the playlist to burn.
Select the device to be used for burning from the right drop-down menu.
Click the Copy button.
This activates the Roxio burning applet screen and creates the CD. When the burning is done, you have a CD that's ready to play in any CD player.
If you have the licenses on your pc, it should ;)
