For nearly all page-building tasks, Yahoo! SiteBuilder allows you to ignore, bypass, and simply forget all about that yucky code lurking underneath the surface. In this way, you can create, design, and edit in peace without fear of being exposed to geeky dust. However, you may wish to incorporate some advanced features and functionality into your Web site -- features that aren't directly supported inside of SiteBuilder itself, including
Yahoo! add-ons that are available from within the Web Hosting Control Panel.
JavaScript scripts that provide additional functionality, such as image effects.
Any HTML markup that you want to add to your site, such as special meta information and code for integrating with a third-party Web service.
Sad actually, but true.
You don't need to actually code to put together something good nowadays.
Although it does help, in understanding how everything is meant to fit
I don't agree Placebo, You do need to know code to make something good. "Good" has changed since back in the day... what Site Builder makes maybe once was considered good... but now not so much
