Most, if not all, e-mail clients allow you to use folders to organize your e-mail. In fact, folders are a great boon to keeping your incoming e-mail uncluttered and under control.
Don't confuse e-mail folders with file folders on your disk drive. Conceptually, they're similar to each other only in that each allows you to organize information. While some e-mail clients may use file folders to store your e-mail, many do not. The folders are maintained within the client as a logical structure, with no relation to file folders on the hard drive.
Rather than leaving all your e-mail in your inbox, give some thought to how you can organize it using folders. For instance, you could have a folder for your work-related e-mail or a folder for each project you're working on. You could also create folders for family e-mail, hobbies, and other categories.
You can configure most (if not all) e-mail clients to display available folders on screen. The folders in Outlook are part of the Navigation pane. When displayed, the pane is at the left side of the program window.
The Navigation pane (or its equivalent) is helpful when working with folders. You can easily drag messages from one folder and drop them in another or move entire folders. To create an e-mail folder, simply right-click an existing folder and choose New Folder. Name the folder and start using it to store messages.
Also note that gmail is a bit different in this regard - it uses 'labels'.
While very similar to folders, an email conversation (as opposed to one mail message - another difference with gmail) can be labelled with multiple labels.
That way, you can cross-reference your emails.
Eg. You might label an email conversation as 'Jokes' and 'Friends' both.
If you click on either Jokes or Friends, that email conversation will appear in the list
Thanks for the info, guys!
