This applies to Windows 2000/XP/2003 Server.
*NOTE* Do not reboot until have have completed all steps.
STEP 1 - The Registry
Start by running regedit and navigate to the following key:
HKEY_CURRENT_USER\\Software\\Microsoft\\Windows\\CurrentVersion\\Run
Runonce
RunOnceEx
R
unServices
RunServicesOnce
HKEY_LOCAL_MACHINE\\Software\\Microsoft\\Windows\\CurrentVersi
on\\Run
Runonce
RunOnceEx
RunServices
RunServicesOnce
Here you will see all the startup programs and services loaded. Inspect the entries carefuly and remove unwanted startup entries. If you are unsure about a startup program, go to
and search for it.
STEP 2 - Cleanup temp files
Click start, run, cleanmgr. On the disk cleanup tab tick all boxes. Click more options tab, click Cleanup next to System Restore. Click YES when prompted, click ok and again click YES when prompted.
To cleanup temporary Internet files, cookies and history you can download
Empty Temp Folders or
CCleanerSTEP 3 - Clean the prefetch
Click start, run, %systemroot%\\Prefetch
Select all files and press delete while holding down SHIFT.
STEP 4 - Schedule a check disk (scandisk)
Click start, run, chkdsk /r
A message appears:
Chkdsk cannot run because the volume is in use by another
process. Would you like to schedule this volume to be
checked the next time the system restarts? (Y/N)
Press Y and enter to schedule the scan.
STEP 5 - Icon Cache
Run Regedit, Go to
HKEY_LOCAL_MACHINE\\Software\\Microsoft\\Windows\\CurrentVersion\\explorer
Create a new string called Max Cached Icons and give it a value of 10000
This will increase response time in windows and give the Shellicon cache file more elbow room.
STEP 6 - Speed up the Network
Run regedit and expand the HKEY_LOCAL_MACHINE key.
Next, expand Software and then Microsoft.
Locate Windows and expand that as well.
You will want to be editing the main system files, so expand CurrentVersion.
Because this feature is a feature of the Windows component known as Explorer, expand the Explorer key.
Next, you will want to modify the remote computer settings, so expand the RemoteComputer key and then expand the NameSpace key to show all of the features that are enabled when you browse to a remote computer.
In the NameSpace folder you will find two entries. One is "{2227A280-3AEA-1069-A2DE-08002B30309D}" which tells Explorer to show printers shared on the remote machine. The other, "{D6277990-4C6A-11CF-8D87-00AA0060F5BF}," tells Explorer to show remote scheduled tasks. This is the one that you should delete. This can be done by right-clicking the name of the key and selecting Delete.
Tip:
If you have no use for viewing remote shared printers and are really only interested in shared files, consider deleting the printers key, "{2227A280-3AEA-1069-A2DE-08002B30309D}", as well. This will also boost your browsing speed.
STEP 7 - Memory Managment
Improving memory performance can be done simply by preventing your hard drive from being used for cache. This is only useful with 256Mb or more of RAM.
Run regedit. Everything that you'll need to edit here can be found in HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Session Manager/Memory Management
Disable Paging Executive
This will prevent pages sections from RAM going to the hard drive. If you have a large amount of RAM at least 256Mb (I suggest 512) you might want to keep the data in your RAM to improve your performance considerably due to reduced amount of hard drive swappage. The entry that you will want to modify is called DisablePagingExecutive. Changing this from 0 to 1 will keep the data in your RAM.
"DisablePagingExecutive"=dword:00000001
System Cache Boost
The XP kernel can be loaded into your RAM with a simple registry edit. This can greatly improve performance since the NT Kernel will always be in your RAM. With this edit you will allocate roughly 4Mb of your RAM for the kernel. Sometimes more RAM is used but most of the time it is only 4Mb. The entry that you will need to find is called LargeSystemCache and you'll need to change this from 0 to 1 in order to enable this.
"LargeSystemCache"=dword:00000001
To put both of these RAM tweaks into use you'll add something like this to your reg file
[HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Control\\Session Mana ger\\Memory Management]
00000001
STEP 8 - Speed up files access
This step is very important and MUST be completed.
Click start, run, defrag c: -f -v
This is a defrag running from the command line. Wait for it to finish or if your prefer the graphical defrag double click My Computer, right click on your C: drive and select properties. Click the Tools tab and click on Defragment now.
STEP 9 - Optimise your startup
Download
Bootvis , install and run. From the Bootvis screen select Trace, Next Boot + Driver Delays. Make the number of repetitions 3 and click ok.
Allow your system to reboot 3 times to rebuild the prefetch. After this process is complete, open Bootvis again. Click Trace, Optimize System and wait for it to finish.
That's it! You will now have a pc that starts quicker and is more responsive. Please feel free to leave your comments and ask any questions. ;)
Christo
