Site Theme Update
1 2 3 4  last
Wed Aug 20 2008, 01:59pm
Christo [PCD] Main Admin Registered Member #1 Joined: Fri Feb 03 2006, 10:48am
Hi
I am currently working on a new look for PCD. The themes may change while u are browsing, but don't be alarmed. Once testing phase is done, i will implement the new theme.
Regards
Site admin
Wed Aug 20 2008, 03:19pm
B@kg@t Registered Member #102 Joined: Mon Apr 03 2006, 05:41pm
Sheesh man,you gave me a helluva fright.looking good tho,keep it up...
Wed Aug 20 2008, 03:29pm
MaTiCa Admin Registered Member #186 Joined: Sun Jul 23 2006, 12:16pm
I thought I was at the wrong site.
Looks good! =)
SpEks
Wed Aug 20 2008, 03:31pm
SpEks Registered Member #24 Joined: Sun Feb 12 2006, 05:13pm
I miss the little animated PCD banner at the top. Tongue
Otherwise, this theme is cool! PCD's first 'dark' theme.
Wed Aug 20 2008, 03:33pm
Could you set it up so that when one scrolls over the emotes their description is shown?
Wed Aug 20 2008, 03:34pm
AJAX, I'll check settings.
SpEks
Wed Aug 20 2008, 03:38pm
Hmmm... I think I've seen this on other forums... When you mouse over threads it displays when it was posted like PCD but it also displays a bit of the first paragraph/post. It'd be cool if PCD could have that too! Cool
Wed Aug 20 2008, 03:44pm
There is still a lot of testing and customization i need to do. Thanks for your suggestions and comments. PCD for the win! Please check out the Light Box plug-in on forum replies. The button to the far right. Click link below
[lightbox=http://www.pcdoctors.co.za/e107_files/public/ 1219239848_1_FT63822_lightbox.jpg]Light Box Plugin[/lightbox]
Wed Aug 20 2008, 04:02pm
Dade_182 Admin Registered Member #308 Joined: Tue May 15 2007, 11:36am
When you view all posts in the post box there's a bullet pic that's not showing. Other than that I like it and like mat I also thought I was on the wrong site.
Wed Aug 20 2008, 04:05pm
Some of the text it being cut off in the forum as well. Or is it because of my low resolution at work? nevermind, nothing is being cut off anymore.
1 2 3 4  last
