Firefox
Dee
Fri Feb 22 2008, 11:40pm
Dee Registered Member #336 Joined: Wed Jul 18 2007, 10:28pm
Okay guys, I really need your help with something, I installed Firefox with a few add-ons and now my whole PC is painfully slow, nothing opens up or operates at normal speed anymore, in fact it's so bad that for each and every action I perform I get "(Not Responding"). Help me please.
PS How do I make photos smaller? I know how to do it for e-mail as it's built in, but this time I don't need to e-mail the photo, I just need to import and upload it to flauntR for editing and effects?
Sat Feb 23 2008, 09:24am
Christo [PCD] Main Admin Registered Member #1 Joined: Fri Feb 03 2006, 10:48am
Which add-ons did you install?
frozenfireside
Sat Feb 23 2008, 11:37am
frozenfireside Registered Member #4 Joined: Fri Feb 03 2006, 12:55pm
respect for using firefox Smile
It *could* be a virus or a lack of ram. Firefox does get a bit full of it's self when you open alot of pages.
If you have added 25+ apps and run a small amount of ram (liek 512megs)then yes, that would slow your system.
Are you running a pentium?
Banlam
Sat Feb 23 2008, 10:07pm
Banlam Registered Member #346 Joined: Wed Aug 22 2007, 06:35pm
Dee wrote ...
You can either do it manually in a program like Paint. But if you have lots of photos to do use Microsoft's (did i actually advise a microsoft product) FREE XP Power Tool "Image Resizer". It's quite useful you just select the images you want resized right click and tell it what size you want them.
JamezV2.0
Sun Feb 24 2008, 04:08am
JamezV2.0 Registered Member #242 Joined: Wed Nov 15 2006, 11:23pm
Dee wrote ...
Dee, go to Google and search for AVG, download their free virus software thingermajigger and give yer sen a scan to see if there are any baddies on your compers. Other than that you could try using Firefox Portable which is a bit smaller and less intensive if FX is slowing your system down. Firefox portable can be found here:
Firefox Portable
PlaceboZA
Sun Feb 24 2008, 02:59pm
PlaceboZA Registered Member #229 Joined: Fri Oct 13 2006, 11:59am
Firefox can't slow down your entire system, unless it's using huge amounts of RAM (working memory) because of addons or something.
Is your computer slow all the time, even if firefox isn't running? Then it's definitely a virus/adware/spyware or some other nasty. And I can assure you that the firefox setup didn't install it Smile
Sun Feb 24 2008, 03:48pm
Add-ons caused Firefox not to respond.
Dee
Sun Feb 24 2008, 11:45pm
Thanks everybody!
